SCSI卡接口定义图
接口定义
119人已加入
SCSI卡接口定义图
SCSI 是 Small Computer System Interface 的缩写,在控制器和设备侧的接口外观为 50 针公插座:
连接电缆为 50 针母插头:
引脚定义
Pin
Name
Dir
Description
01
GND
Ground
02
GND
Ground
03
+DB0
+Data Bus 0
04
-DB0
-Data Bus 0
05
+DB1
+Data Bus 1
06
-DB1
-Data Bus 1
07
+DB2
+Data Bus 2
08
-DB2
-Data Bus 2
09
+DB3
+Data Bus 3
10
-DB3
-Data Bus 3
11
+DB4
+Data Bus 4
12
-DB4
-Data Bus 4
13
+DB5
+Data Bus 5
14
-DB5
-Data Bus 5
15
+DB6
+Data Bus 6
16
-DB6
-Data Bus 6
17
+DB7
+Data Bus 7
18
-DB7
-Data Bus Parity7
19
+DBP
+Data Bus Parity (odd Parity)
-DBP
-Data Bus Parity (odd Parity)
21
DIFFSENS
22
GND
Ground
23
res
Reserved
24
res
Reserved
25
TERMPWR
Termination Power
26
TERMPWR
Termination Power
27
res
Reserved
28
res
Reserved
29
+ATN
+Attention
30
-ATN
-Attention
31
GND
Ground
32
GND
Ground
33
+BSY
+Bus is busy
34
-BSY
-Bus is busy
35
+ACK
+Acknowledge
36
-ACK
-Acknowledge
37
+RST
+Reset
38
-RST
-Reset
39
+MSG
+Message
40
-MSG
-Message
41
+SEL
+Select
42
-SEL
-Select
43
+C/D
+Control or Data
44
-C/D
-Control or Data
45
+REQ
+Request
46
-REQ
-Request
47
+I/O
+In/Out
48
-I/O
-In/Out
49
GND
Ground
50
GND
Ground
  • 相关推荐
  • 热点推荐
