接口定义
外置SCSI高密接口引脚定义(差分信号方式)
SCSI 是 Small Computer System Interface 的缩写,外置式高密 50 针接口的外观为母插座:
连接电缆插头为 50 针公插头:
引脚定义 |
Pin |
Name |
Dir |
Description |
01 |
GND |
Ground | |
02 |
+DB0 |
+Data Bus 0 | |
03 |
+DB1 |
+Data Bus 1 | |
04 |
+DB2 |
+Data Bus 2 | |
05 |
+DB3 |
+Data Bus 3 | |
06 |
+DB4 |
+Data Bus 4 | |
07 |
+DB5 |
+Data Bus 5 | |
08 |
+DB6 |
+Data Bus 6 | |
09 |
+DB7 |
+Data Bus 7 | |
10 |
+DBP |
+Data Bus Parity (odd Parity) | |
11 |
DIFFSENS |
12 |
res |
Reserved |
13 |
TERMPWR |
Termination Power | |
14 |
res |
Reserved |
15 |
+ATN |
+Attention | |
16 |
GND |
Ground | |
17 |
+BSY |
+Bus is busy | |
18 |
+ACK |
+Acknowledge | |
19 |
+RST |
+Reset | |
20 |
+MSG |
+Message | |
21 |
+SEL |
+Select | |
22 |
+C/D |
+Control or Data | |
23 |
+REQ |
+Request | |
24 |
+I/O |
+In/Out | |
25 |
GND |
Ground | |
26 |
GND |
Ground | |
27 |
-DB0 |
-Data Bus 0 | |
28 |
-DB1 |
-Data Bus 1 | |
29 |
-DB2 |
-Data Bus 2 | |
30 |
-DB3 |
-Data Bus 3 | |
31 |
-DB4 |
-Data Bus 4 | |
32 |
-DB5 |
-Data Bus 5 | |
33 |
-DB6 |
-Data Bus 6 | |
34 |
-DB7 |
-Data Bus Parity7 | |
35 |
-DBP |
-Data Bus Parity (odd Parity) | |
36 |
GND |
Ground | |
37 |
res |
Reserved |
38 |
TERMPWR |
39 |
res |
Reserved |
40 |
-ATN |
-Attention | |
41 |
GND |
Ground | |
42 |
-BSY |
-Bus is busy | |
43 |
-ACK |
-Acknowledge | |
44 |
-RST |
-Reset | |
45 |
-MSG |
-Message | |
46 |
-SEL |
-Select | |
47 |
-C/D |
-Control or Data | |
48 |
-REQ |
-Request | |
49 |
-I/O |
-In/Out | |
50 |
GND |
Ground |
