嵌入式操作系统
c语言键盘扫描程序
4*4
/* 4x4
#include
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P2_7=P2^7;
sbit P3_7=P3^7;
unsigned char code table[]={0xC0,0xF9,0xA4,0xB0,0x99, //0~4
0x92,0x82,0xF8,0x80,0x90, //5~9
0x88,0x83,0xC6,0xA1,0x86,0x8E}; //A~F
void KeyScan();
void delay10ms(unsigned char time);
void Dispaly(unsigned char k);
void buzzer();
unsigned char key,temp;
void main() //主程序
while(1)
KeyScan();
void KeyScan() //
P1=0xFF;
P1_0=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
{buzzer();
delay10ms(10);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0xE0:
key=0;break;
case 0xD0:
key=4;break;
case 0xB0:
key=8;break;
case 0x70:
key=12;break;
Dispaly(key);
P1=0xFF;
P1_1=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
{buzzer();
delay10ms(10);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0xE0:
key=1;break;
case 0xD0:
key=5;break;
case 0xB0:
key=9;break;
case 0x70:
key=13;break;
Dispaly(key);
P1=0xFF;
P1_2=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
{buzzer();
delay10ms(10);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0xE0:
key=2;break;
case 0xD0:
key=6;break;
case 0xB0:
key=10;break;
case 0x70:
key=14;break;
Dispaly(key);
P1=0xFF;
P1_3=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
{buzzer();
delay10ms(10);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0xE0:
key=3;break;
case 0xD0:
key=7;break;
case 0xB0:
key=11;break;
case 0x70:
key=15;break;
Dispaly(key);
//延时程序
unsigned char i;
while(time--)
for(i=0;i<120;i++) ;
void Dispaly(unsigned char k) //显示程序
P0=table[k];
P2_7=0;
void buzzer()
P3_7=0;
delay10ms(20);
P3_7=1;
6x3扫描键盘驱动程序(C语言编写)
〖说明〗18个按键扫描驱动程序,横向扫描第一行:p0.6 第二行:p0.7 第三行:p2.6
纵向扫描:第一行:p0.0 第二行:p0.1 第三行:p0.2 第四行:p0.3 第五行:
p0.4 第六行:p0.5
〖文件〗key.c 2002/12/10
〖作者〗鞠春阳
〖信箱〗jcygood@163.net jcygood@sina.com
〖版本〗v1.00a build
//#i nclude "reg51.h"
//#i nclude "lcd12864.h"
#define port p0 //定义p0口
sbit p2_6=p2^6; //定义p2.6口
unsigned int zdtime=0;
unsigned int pingbaotime=0;
/*定义18个按键的返回值*/
#define runkey 1
#define stopkey 2
#define upkey 3
#define downkey 4
#define a_c 5
#define d_f 6
#define g_i 7
#define j_l 8
#define m_o 9
#define p_s 10
#define t_v 11
#define w_z 12
#define pageupkey 13
#define pagedownkey 14
#define enterkey 15
#define backkey 16
#define chineseorenglish 17
#define cancelkey 18
//按键扫描函数
unsigned char getkey()
unsigned char a,b;
unsigned int delay=0; //延时变量
port=0xff; //p0口复位
p2_6=1; //p2.6复位
//扫描第三行
p2_6=0;
while(!(port&0x01))
if(++delay>0x1ff0) { return(pagedownkey);}
while(!(port&0x02))
if(++delay>0x1ff0) { return(chineseorenglish);}
while(!(port&0x04))
if(++delay>0x1ff0) { return(backkey);}
while(!(port&0x08))
if(++delay>0x1ff0) { return(pageupkey);}
while(!(port&0x10))
if(++delay>0x1ff0) { return(cancelkey);}
while(!(port&0x20))
if(++delay>0x1ff0) { return(enterkey);}
port=0xff; //p0口复位
p2_6=1; //p2.6复位
//扫描第一行
port=0x7f;
delay=0;
while(!(port&0x01))
if(++delay>0x1ff0) { return(downkey);}
if(delay>0xff0) { return(downkey); }
while(!(port&0x02))
if(++delay>0x1ff0) { return(stopkey);}
if(delay>0xff0) { return(stopkey); }
while(!(port&0x04))
if(++delay>0x5fd0) { return(w_z);}
if(delay>0xff0) { return(w_z); }
while(!(port&0x08))
if(++delay>0x5fd0) { return(t_v);}
if(delay>0xff0) { return(t_v); }
while(!(port&0x10))
if(++delay>0x5fd0) { return(p_s);}
if(delay>0xff0) { return(p_s); }
while(!(port&0x20))
if(++delay>0x5fd0) { return(m_o);}
if(delay>0xff0) { return(m_o); }
port=0xff; //p0口复位
p2_6=1; //p2.6复位
//扫描第二行
port=0xbf;
delay=0;
while(!(port&0x01))
if(++delay>0x1ff0) { return(upkey);}
if(delay>0xff0) { return(upkey); }
while(!(port&0x02))
if(++delay>0x1ff0) { return(runkey);}
if(delay>0xff0) { return(runkey); }
while(!(port&0x04))
if(++delay>0x5fd0) { return(j_l);}
if(delay>0xff0) { return(j_l); }
while(!(port&0x08))
if(++delay>0x5fd0) { return(g_i);}
if(delay>0xff0) { return(g_i); }
while(!(port&0x10))
if(++delay>0x5fd0) { return(d_f);}
if(delay>0xff0) { return(d_f); }
while(!(port&0x20))
if(++delay>0x5fd0) { return(a_c);}
if(delay>0xff0) { return(a_c); }
return(0);
3x4矩阵键盘的扫描程序(C语言)
/* 3x4矩阵键盘的扫描程序
按相应的按键,数码管显示相应的数字,星号键和井号键分别显示为E和F
Create by:左秀龙
support:
Tel:0755-82879296
email: cutedesign@tom.com
Date: 2005/06/23
测试通过*/
#include
0x88,0x83,0xA7,0xA1,0x86,0x8E}; //A~F
void KeyScan();
void main() //主程序
while(1)
KeyScan();
void KeyScan() //按键扫描子程序
P1=0xFF;
P1_3=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
delay10ms(1);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0x70:
key=1;break;
case 0xB0:
key=2;break;
case 0xD0:
key=3;break;
Dispaly(key);
P1=0xFF;
P1_2=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
delay10ms(1);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0x70:
key=4;break;
case 0xB0:
key=5;break;
case 0xD0:
key=6;break;
Dispaly(key);
P1=0xFF;
P1_1=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
delay10ms(1);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0x70:
key=7;break;
case 0xB0:
key=8;break;
case 0xD0:
key=9;break;
Dispaly(key);
P1=0xFF;
P1_0=0;
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
delay10ms(1);
temp=P1;
temp&=0xF0;
if(temp !=0xF0)
temp=P1;
temp&=0xF0;
switch(temp)
case 0x70:
key=14;break;
case 0xB0:
key=0;break;
case 0xD0:
key=15;break;
Dispaly(key);
//延时程序
unsigned char a,b,c;
for(a=0;a
P0=table[k];
P2_1=0;
