信步科技SV1-H611A-B嵌入式主板优势介绍
Intel 2代、3代Core i3/i5/i7处理器(LGA1155), 10*COM, 1*LAN, 1*PCI-E, 1*Mini-PCIe
支持Intel 2代、3代Core i3/i5/i7处理器(LGA1155)
采用Intel H61芯片组
提供10*COM、8*USB, 1*千兆LAN
提供1*VGA, 1*HDMI, 支持双屏异显
提供1*PCI-E 16X, 1*Mini-PCIe
规格
General
CPU Intel® Pentium®/ Celeron®/ 2nd and 3rd Generation CoreTM i3/i5/i7 CPU, LGA1155
Chipset Intel® H61 Chipset, TDP 6.1W
Memory Up to 16 GB DDR3 1333/1066 MHz, 2*DIMM
Storage 2*SATA 2.0
Expansion Interface 1*PCI-E 16X, 1*Mini-PCIe(Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows XP/7/8/10, Linux
I/O Interface
Serial Port 10*RS232(COM3 RS485 optional)
USB 8*USB 2.0(4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1* LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface 1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
