信步科技SV3b-19016EP嵌入式主板介绍
Intel Bay Trail J1900处理器, 6*COM, 9*USB, 支持双eDP显示, 背置CPU, 3.5寸 (146*105mm)
  • 采用Intel Bay Trail 单芯片处理器
  • 6*COM, 9*USB, 1*千兆网卡
  • 1*VGA, 2*eDP, 支持双eDP独立显示
  • 2*Mini-PCIe支持mSATA和Wifi/3G/4G
  • 3.5寸, DC 12V供电
规格
General
CPU Intel® Celeron® J1900[1] CPU, Quad-core, up to2.42 GHz, TDP 10W
Chipset Null
Memory DDR3L-1333, 1*SO-DIMM, up to 8 GB
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows7/8/10, Linux
I/O Interface
Serial Port 5*RS232, 1*TTL
USB 1*USB 3.0, 8*USB 2.0
Ethernet 1*Realtek® 1Gbps PCIe Ethernet Controller, RJ45
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
2*eDP: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 146*105mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
WINDOWS
