信步科技SKM-Q170嵌入式主板介绍
Smart Kiosk Box Computer based on Intel SKM, dedicated to Kiosks in Banking, Transportation, Healthcare and Public segments.
  • Separate compute module from IO docking board, Easier maintenance and upgradability.
  • compute module can fits different IO expansion module to met wide range of Kiosk application.
  • Support Intel® 6/7th Gen Core i3/i5/i7 & Pentium®/ Celeron® Processor (Skylake/ Kaby Lake) with Intel® Q170 Chipset
  • 2*SO-DIMM, Up to 32 GB DDR4 1866/2133 MHz
  • 1*M.2 Key M 2280 (NVME SSD), 1*M.2 Key E 2230 (WiFi/BT), 1*PCI-E 1X
  • 10*COM, 2*USB 3.0, 10*USB 2.0, 2*SATA 3.0
  • 1*Intel GbE LAN, supports Intel® vPro™ Technology
  • Supports Dual display of VGA and HDMI
规格
General
CPU Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® Q170 Chipset, TDP 6W
Memory Up to 32 GB DDR4 1866/2133 MHz, 2*SO-DIMM
Storage 2*SATA 3.0
Expansion Interface
1*PCI-E 1X
BIOS AMI UEFI BIOS
System Window 10 64-bit, Linux
I/O Interface
Serial Port 10*RS232
USB 2*USB 3.0, 10*USB 2.0
Ethernet 1*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
Feature Interface null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 259.1mm*201.4mm* 89.6mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
嵌入式主板
嵌入式主板
