信步科技SV-32B54嵌入式主板介绍
ARM Rockchip RK3288处理器, 4*COM, 9*USB, 1*LAN, 1*钱箱专用接口, 1*MIPI-CSI, 板载WiFI+蓝牙
  • 采用ARM Rockchip RK3288处理器
  • 板载1/2/4G内存, 8/16/32G EMMC存储
  • 提供4*COM, 9*USB, 1*千兆LAN
  • 提供1*VGA, 1*eDP, 1*LVDS, 支持双显
  • 提供1*RJ11钱箱专用接口, 1*MIPI-CSI摄像头接口
  • 提供1*Mini-PCIe (支持3G), 板载WIFI+蓝牙
规格
General
CPU ARM Rockchip® RK3288, Quad-Core Cortex-A17 up to 1.8GHz
Chipset Null
Memory 1/2/4GB DDR3 1333MHz on board
Storage 1*EMMC 8/16/32G, 1*TF Card
Expansion Interface 1*Mini-PCIe (3G Supported)
BIOS Null
System Android 5.1, Linux kernel 3.10 (Watchdog Timer Supported)
I/O Interface
Serial Port 4*RS232 (COM5 TTL optional)
USB 9*USB 2.0
Ethernet
1*Realtek® PHY LAN for 1000Mbps
1*Realtek® WIFI (IEEE 802.11 b/g/n, 2.4GHz)
1*BT (FHSS BT3.0/4.0)
Audio Everest® CODEC ES8316, supports MIC/Line-out
PS/2 Null
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface
1*Cash Drawer Connector (RJ11)
1*MIPI-CSI Camera Connector
Display
Display Interface
1*VGA: max resolution up to 1920*1080@60Hz
1*eDP: max resolution up to 4096*2160@30Hz
1*LVDS: Single Channel 24 bit, max resolution up to 1920*1080@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 3.5” , 146*105mm
Power Input DC 24V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
安卓
安卓
