信步科技SV-32A66嵌入式主板介绍
ARM Rockchip RK3288 处理器, 6*COM, 6*USB, 1*LAN, 1*Mini-PCIe, 2*触摸屏接口, 板载WiFI+蓝牙
  • 采用ARM Rockchip RK3288处理器
  • 板载1/2/4G 内存, 8/16/32G EMMC存储
  • 提供6*COM, 6*USB, 1*千兆LAN
  • 提供1*HDMI, 1*eDP, 1*LVDS/eDP, 2*触摸屏接口
  • 提供1*Mini-PCIe (支持3G), 板载WIFI+蓝牙
规格
General
CPU ARM Rockchip® RK3288, Quad-Core Cortex-A17 up to 1.8GHz
Chipset Null
Memory 1/2/4GB DDR3 1333MHz on board
Storage 1*EMMC 8/16/32G, 1*TF Card
Expansion Interface 1*Mini-PCIe (3G Supported)
BIOS Null
System Android 4.4/5.1/7.1
I/O Interface
Serial Port 6*RS232 (COM1 RS485 optional)
USB 6*USB 2.0
Ethernet
1*Realtek® PHY LAN for 1000Mbps
1*Realtek® WIFI (IEEE 802.11 b/g/n, 2.4GHz)
1*BT (FHSS BT3.0/4.0)
Audio
Everest® CODEC ES8316, supports MIC/Line-out
1*Amplifier
PS/2 Null
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface
2*Touch Panel Header (only with USB signal)
1*Infrared Pin Header
Display
Display Interface
1*HDMI: max resolution up to 4096*2160@60Hz
1*eDP: max resolution up to 4096*2160@30Hz
1*LVDS/eDP: LVDS, Dual Channel 24 bit, max resolution up to 1920*1080@60Hz
                      eDP, max resolution up to 4096*2160@30Hz
Multiple Display Dual
Mechanical & Environment
Dimension 3.5”, 146*105mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
安卓
安卓
