ARM Freescale I.MX6 双核处理器, 6*COM, 6*USB, 1*LAN, 1*Mini-PCIe, 2*触摸屏接口,板载WiFI+蓝牙
| General | |
| CPU | ARM Freescale® I.MX6 Cortex-A9, Dual-Core up to 1.0GHz |
| Chipset | Null |
| Memory | 1/2/4GB DDR3 1333MHz on board |
| Storage | 1*EMMC 8/16/32G, 1*TF Card |
| Expansion Interface | 1*Mini-PCIe (3G Supported) |
| BIOS | Null |
| System | Android 4.4.2, Linux kernel 3.0.35 |
| I/O Interface | |
| Serial Port | 6*RS232 |
| USB | 6*USB 2.0 |
| Ethernet |
1*Realtek® PHY LAN for 1000Mbps 1*Realtek® WIFI (IEEE 802.11 b/g/n, 2.4GHz) 1*BT (FHSS BT3.0/4.0) |
| Audio |
Everest® CODEC ES8316, supports MIC/Line-out 1*Amplifier |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | 1 programmable GPIO |
| Feature Interface | 2*Touch Panel Header (only with USB signal) |
| Display | |
| Display Interface |
1*HDMI: max resolution up to 1920*1080@120Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 3.5", 146*105mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
