信步科技SV-6QA68嵌入式主板介绍
ARM Freescale I.MX6 四核处理器, 9*COM, 8*USB, 2*LAN, 1*Mini-PCIe, 板载WiFI+蓝牙
  • 采用ARM Freescale I.MX6 Cortex-A9 四核处理器
  • 板载1/2/4G内存, 8/16/32G EMMC存储
  • 提供9*COM, 8*USB, 2*千兆LAN
  • 提供1*VGA, 1*HDMI, 1*LVDS, 支持双显
  • 提供1*Mini-PCIe (支持3G), 板载WIFI+蓝牙
规格
General
CPU ARM Freescale® I.MX6 Cortex-A9, Quad-Core up to 1.2GHz
Chipset Null
Memory 1/2/4GB DDR3 1066MHz on board
Storage 1*EMMC 8/16/32G, 1*SATA 2.0, 1*SD Card
Expansion Interface 1*Mini-PCIe (3G Supported)
BIOS Null
System Android 4.4.2, Linux kernel 3.0.35
I/O Interface
Serial Port 9*RS232
USB 8*USB 2.0
Ethernet
1*Realtek® PCI-E LAN for 1000Mbps
1*Realtek® PHY LAN for 1000Mbps
1*Realtek® WIFI (IEEE 802.11 b/g/n, 2.4GHz)
1*BT (FHSS BT3.0/4.0)
Audio Freescale® CODEC, supports MIC/Line-out
PS/2 Null
Parallel Port Null
GPIO 6 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1080@60Hz
1*HDMI: max resolution up to 1920*1080@120Hz
1*LVDS: Single Channel 24 bit, max resolution up to 1366*768@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 140*200mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
