信步科技SV1a-70216EP嵌入式主板介绍
Intel Kaby Lake-U Core i3-7020U处理器, 6*COM, 10*USB, 支持双eDP显示, 提供钱箱接口
  • 采用Intel Kabylake-U Core i3-7020U处理器
  • 提供6*COM, 10*USB, 1*千兆LAN
  • 提供1*VGA, 1*HDMI/eDP, 1*LVDS/eDP, 支持三屏异显
  • 提供钱箱专用RJ11接口
  • 提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
  • 薄型Mini-ITX, 板身厚度≤17mm
规格
General
CPU Intel® CoreTM i3-7020U, Dual-core, clock speed2.30 GHz, TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows7/8/10, Linux
I/O Interface
Serial Port 6*RS232
USB 2*USB 3.0, 8*USB 2.0
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface
1*RJ11 Port (Cash Drawer)
1*Cash2 Open Pin Header
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
1*HDMI/eDP: HDMI 1.4b, max resolution up to 4096*2160@24Hz
                     eDP, max resolution up to 1920*1200@60Hz
Multiple Display Triple
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
