信步科技SV1-H112A嵌入式主板介绍
Intel 6/7代Core i3/i5/i7处理器(LGA1151), 10*COM, 10*USB, 2*LAN, 1*PCI-E 16X, 2*Mini-PCIe
  • 支持Intel 6/7代Core i3/i5/i7处理器(LGA1151)
  • 采用Intel H110芯片组
  • 提供10*COM, 10*USB, 2*千兆LAN
  • 提供1*VGA, 1*HDMI, 支持双屏异显
  • 提供1*PCI-E 16X, 2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
规格
General
CPU Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® H110 Chipset, TDP 6W
Memory Up to 32 GB DDR4 2133 MHz, 2*DIMM
Storage 2*SATA 3.0, 1*mSATA
Expansion Interface 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows7/8/10, Linux
I/O Interface
Serial Port 10*RS232
USB 2*USB 3.0, 8*USB 2.0
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display
Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
