信步科技SV1a-40516P嵌入式主板介绍
Intel Gemini Lake系列处理器, 6*COM, 10*USB, 支持三屏异显, 提供M.2, 可选eMMC, DC 12V供电
  • 采用Intel Gemini Lake J4005处理器
  • 提供6*COM, 10*USB, 1*千兆LAN
  • 提供1*VGA, 1*HDMI/eDP, 1*LVDS/eDP, 支持三屏异显
  • 提供M.2接口, 可选eMMC存储
  • 采用DC 12V供电
  • 薄型Mini-ITX, 板身厚度≤17mm
规格
General
CPU Intel® Gemini Lake J4005 CPU, Dual-core, up to 2.7 GHz, TDP 10W
Chipset Null
Memory Up to 8GB DDR4 2400 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*M.2, eMMC optional
Expansion Interface 1*Mini-PCIe (Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 10, Linux
I/O Interface
Serial Port 6*RS232
USB 4*USB 3.0, 6*USB 2.0
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2 header
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface 1*Cash Drawer control header
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI/eDP: HDMI, max resolution up to 4096*2160@60Hz
1*LVDS/eDP: LVDS, Dual Channel 24bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 4096*2160@60Hz
Multiple Display Triple
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
