Intel® Coffee Lake 8th Gen Core i3/i5/i7 CPU (LGA1151) with Q370, 4*COM, 8*USB, 2*Intel LAN, 3*SATA 3.0, 1*M.2
| General | |
| CPU | Intel® Pentium®/ Celeron®/ 8th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
| Chipset | Intel® Q370 Chipset, TDP 6W |
| Memory | Up to 32 GB DDR4 2400 MHz, 2*SO-DIMM |
| Storage | 3*SATA 3.0, 1*mSATA |
| Expansion Interface |
1*PCI-E 16X, 1*Mini-PCIe 1*M.2 (PCIe X4 support - also supports SATA & PCIe X2) |
| BIOS | AMI UEFI BIOS |
| System | Windows 10 x64, Linux |
| I/O Interface | |
| Serial Port | 4*RS232 |
| USB | 4*USB 3.0, 4*USB 2.0 |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*HDMI 1.4b:max resolution up to 4096*2160 2*DP:max resolution up to 4096*2160 1*LVDS:Dual Channel 24bit LVDS, max resolution up to 1920*1200 |
| Multiple Display | Triple |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
