Intel® Apollo Lake Celeron N3450 CPU, 6*COM, 9*USB, Supports triple display, 1*M.2, DC 12V Input
| General | |
| CPU | Intel® Apollo Lake Celeron® N3450 CPU, Quad-core, up to 2.2 GHz, TDP 6W |
| Chipset | Null |
| Memory | Up to 16GB DDR3L 1866 MHz, 2*SO-DIMM |
| Storage | 1*SATA 3.0, 1*mSATA, 1*NGFF |
| Expansion Interface |
1*Mini-PCIe (mSATA Supported) 1*M.2 (PCIe X4 support - also supports SATA & PCIe X2) |
| BIOS | AMI UEFI BIOS |
| System | Windows 10 x64, Linux |
| I/O Interface | |
| Serial Port | 6*RS232 |
| USB | 5*USB 3.0, 4*USB 2.0 |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifier |
| PS/2 | 1*PS/2 |
| Parallel Port | 1*LPT |
| GPIO | Null |
| Feature Interface | 1*CashDrawer Control Port |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI: max resolution up to 4096*2160 1*eDP : max resolution up to 2560*1600 |
| Multiple Display | Triple |
| Mechanical & Environment | |
| Dimension | 218*155mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
