Intel® Kaby Lake-U Celeron 3865U CPU, 4*COM, 10*USB, 1*LAN, 2*LVDS, 2*Mini-PCIe, DC 12V Input
| General | |
| CPU | Intel® Kaby Lake-U 3865U CPU, Dual-core, 1.8GHz, TDP 15W |
| Chipset | Null |
| Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 2.0, 1*mSATA |
| Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux |
| I/O Interface | |
| Serial Port | 4*RS232 |
| USB | 2*USB 3.0, 8*USB 2.0 (6*on rear I/O, 4*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifier |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | Null |
| Feature Interface | 1*CashDrawer Port |
| Display | |
| Display Interface | 2*LVDS: Single Channel 18/24bit LVDS, max resolution up to 1920*1200 |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 121*256mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
