信步科技SV-KBL-U5嵌入式主板介绍
Intel® Kaby Lake-U Celeron® 3865U CPU, Double-layer Rear I/O which can expand to 18*COM and 16*USB
  • Intel® Kaby Lake-U Celeron® 3865U CPU
  • Double-layer Rear I/O which can expand to 18*COM and 16*USB (use SV-M5 I/O Extension Modules)
  • Supports triple display of VGA, HDM and LVDS/eDP
  • 2*1000 Mbps LAN and 1*PCI-E 4X
  • 2*Mini-PCIe (Supports 1*mSATA, 1*Wifi+3G/4G)
规格
General
CPU Intel® Kaby Lake-U Celeron® 3865U CPU, Dual-core,1.8 GHz,TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*mSATA
Expansion Interface
1*PCI-E 16X (4X Signal)
2*Mini-PCIe (1*mSATASupported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows7/8/10, Linux
I/O Interface
Serial Port 6*RS232 (Up to 18*RS232 with SV-M5-CU)
USB 2*USB 3.0, 8*USB 2.0 (Up to 16*USB with SV-M5-CU)
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200
1*HDMI:max resolution up to 4096*2160
1*LVDS/eDP:Dual Channel 24bit, max resolution up to 1920*1200
eDP max resolution upto 1920*1080
Multiple Display Triple
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU or DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
WINDOWS
