信步科技SV-KBL-U4嵌入式主板介绍
Intel® Kaby Lake-U Celeron 3865U CPU, OPS, Dual display of VGA and HDMI, 4K UHD, Wifi+BT Module on board, DC 12V Input
  • Intel® Kaby Lake-U Celeron 3865U CPU
  • Provides OPS port for Digital White Board
  • Supports Dual display of VGA and HDMI, 4K UHD
  • Supports mSATA SSD, Wifi+BT Module on board
  • Supports DC 12V Input
规格
General
CPU Intel®  Kaby Lake-U Celeron® 3855U CPU, Dual-core, 1.8 GHz,TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM
Storage 1*SATA 3.0 (22Pin), 1*mSATA
Expansion Interface
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported)
1*OPC Port
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 1*RS232
USB 2*USB 3.0+2*USB 2.0 (rear I/O), 1*USB 3.0+2*USB 2.0 (OPS)
Ethernet
1*Realtek® PCI-E LAN for 1000Mbps
1*Realtek® Wifi+BTmodule 2.4 GHz
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 Null
Parallel Port Null
GPIO Null
Feature Interface 1*Antenna Terminal Connector
Display
Display Interface
1*VGA: max resolution up to 2560*1600
1*HDMI:max resolution up to 1920*1200
1*OPS_HDMI: max resolutionup to 4096*2160
Multiple Display Dual
Mechanical & Environment
Dimension 170*190mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
