信步科技SV1-38526C嵌入式主板介绍
Intel Skylake-U 3855U处理器, 双层I/O设计, 可扩展至18*COM, 16*USB
  • 支持Intel Skylake-U Celeron 3855U处理器
  • 采用双层I/O设计, 可搭配SV-M5子卡, 扩展至18*COM, 18*USB
  • 提供1*VGA, 1*HDMI, 1*LVDS/eDP, 支持三屏异显
  • 提供2*千兆LAN, 1*PCI-E 4X
  • 提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
规格
General
CPU Intel® Skylake-U Celeron® 3855U CPU, Dual-core, 1.6 GHz, TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*mSATA
Expansion Interface
1*PCI-E 16X (4X Signal)
2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows7/8/10, Linux
I/O Interface
Serial Port 6*RS232 (Up to 18*RS232 with SV-M5-CU)
USB 2*USB 3.0, 8*USB 2.0 (Up to 16*USB with SV-M5-CU)
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 1920*1200@60Hz
Multiple Display Triple
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU or DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
嵌入式主板
