信步科技SV1a-34516P特征英文版
Intel Apollo Lake Celeron N3450 CPU, 6*COM, 10*USB, Supports triple display, 2*Mini-PCIe, DC 12V Input
  • Intel Apollo Lake Celeron N3450 CPU
  • 6*COM, 10*USB, 1*1000 Mbps LAN
  • Supports triple display of VGA, HDMI/eDP and LVDS/eDP
  • 2*Mini-PCIe (Support 1*mSATA, 1*Wifi/3G/4G)
  • Supports DC 12V Input
  • Thin Mini-ITX (thickness≤17mm)
规格
General
CPU Intel® Apollo Lake Celeron® N3450 CPU, Quad-core, up to 2.2 GHz, TDP6W
Chipset Null
Memory Up to 8 GB DDR3L 1866 MHz, 1*SO-DIMM
Storage 2*SATA 3.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*Wifi/3G/4G Supported, 1*mSATA Supported)
BIOS AMI UEFI BIOS
System Windows 10 x64, Linux
I/O Interface
Serial Port 6*RS232
USB 2*USB 3.0, 8*USB 2.0
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2 header
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI/eDP: HDMI, max resolution up to 3840*2160@30Hz;
1*LVDS/eDP: LVDS, Dual Channel 24bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 4096*2160@60Hz
Multiple Display Triple
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
