信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
  • Supports Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with Intel H110 chipset
  • 6*COM, 10*USB, 1*1000 Mbps LAN
  • With SVIO support SV-M6 I/O Module to extend COM/USB/PCI
  • Supports dual display of VGA, HDMI and LVDS/eDP
  • 2*Mini-PCIe (Support 1*mSATA, 1*Wifi/3G/4G)
规格
General
CPU Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® H110 Chipset, TDP 6W
Memory Up to 16 GB DDR4 2133/1866 MHz, 1*SO-DIMM
Storage 2*SATA 3.0, 1*mSATA
Expansion Interface 2*Mini-PCIe(1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows7/8/10, Linux
I/O Interface
Serial Port 6*RS232
USB 4*USB 3.0, 6*USB 2.0 (4*on rear I/O, 6*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2 header
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 4096*2160@24Hz /2560*1600@60Hz
1*LVDS/eDP: Dual Channel 24bit LVDS, max resolution up to 1920*1200@60Hz
eDP max resolution up to 2880x1800@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
