Intel® Kaby Lake-U Celeron 3865U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
| General | |
| CPU | Intel® Kaby Lake-U Celeron 3865U CPU, Dual-core, up to 1.80GHz, TDP 15W |
| Chipset | Null |
| Memory | Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0, 1*mSATA |
| Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux |
| I/O Interface | |
| Serial Port | 6*RS232 (COM6 RS485 optional) |
| USB | 7*USB 2.0 (2*on rear I/O, 5*header) |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO |
| Feature Interface | 1*SVIO Connector |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI: max resolution up to 1920*1200 1*LVDS/eDP: DualChannel 24bit LVDS, max resolution up to 1920*1200; eDP max resolution up to 1920*1080 |
| Multiple Display | Triple |
| Mechanical & Environment | |
| Dimension | 3.5'', 146*105mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
