信步科技NVR SV4-B15B4规格英文版
  Intel LGA1151 CPU with B150, 25*SATA, 3*1000 Mbps Intel LAN, 12*USB, 2*PCI-E, 1*Mini-PCIe, ATX (305*244mm)
  Supports Intel 6th/7th Core i3/i5/i7 and Pentium/ Celeron LGA1151 CPU with Intel B150 chipset
  6*Mini-SAS (24*SATA), 3*1000 Mbps Intel LAN
  1*PCI-E 16X, 1*PCI-E 4X, 1*Mini-PCIe
  Supports triple display of 1*VGA and 3*HDMI
规格
General
CPU Intel® Pentium®/ Celeron® /Xeon® 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® B150 Chipset, TDP 6W
Memory Up to 32 GB DDR4 2133/1866 MHz, 4*DIMM
Storage 6*Mini-SAS (24*SATA), 1*SATA 3.0, 1*mSATA
Expansion Interface 1*PCI-E 16X, 1*PCI-E 4X, 1*Mini-PCIe (mSATA/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Server 2008/2012, Linux
I/O Interface
Serial Port 2*RS232 (1*RS485 optional)
USB 4*USB 3.0, 8*USB 2.0 (4*on rear I/O, 8*header)
Ethernet 3*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
3*HDMI: max resolution up to 4096*2160@30Hz
Multiple Display Triple
Mechanical & Environment
Dimension ATX, 305*244mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
