信步科技SV1-19016EP规格
Intel Bay Trail J1900处理器, 6*COM, 提供钱箱和触摸屏专用接口, 支持双eDP显示, DC12V或ATX供电可选
  • 采用Intel Bay Trail J1900处理器
  • 提供6*COM, 8*USB, 1*千兆LAN
  • 提供1*VGA, 1*VGA/eDP, 1*LVDS/eDP, 支持双eDP显示
  • 提供钱箱专用RJ11接口, 触摸屏控制接口
  • DC 12V或ATX供电可选
规格
General
CPU Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W
Chipset Null
Memory Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage 2*SATA 2.0
Expansion Interface 1*Mini-PCIe (mSATA/WiFi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux, Android
I/O Interface
Serial Port 6*RS232 (COM5 TTL optional)
USB 1*USB 3.0, 7*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 (Keyboard Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface
1*RJ11 Port (Cash Drawer)
1*Touch Panel Controller Pin Header
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
1*VGA/eDP: VGA, max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU or DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
安卓
安卓
