信步科技SV1-38516P规格
Intel Skylake-U 3855U处理器, 6*COM, 11*USB, 1*LAN, 1*VGA, 1*LVDS/eDP, 1*Mini-PCIe, DC 12V供电
  • 采用Intel Skylake-U 3855U处理器
  • 提供6*COM, 11*USB, 1*千兆LAN
  • 提供1*VGA, 1*LVDS/eDP, 支持双屏异显
  • 提供1*Mini-PCIe (支持mSATA/3G/4G)
  • 采用DC 12V供电
规格
General
CPU Intel® Skylake-U 3855U CPU, Dual-core, 1.6 GHz, TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*mSATA
Expansion Interface 1*Mini-PCIe (mSATA/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 6*RS232 (COM6 TTL optional)
USB 2*USB 3.0, 9*USB 2.0 (4*on rear I/O, 7*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface
1*Cash Drawer wafer
1*Touch Pannel Controller
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
