信步科技NVR SV4-B15B4规格
Intel LGA1151全系列处理器, 25*SATA, 3*Intel千兆LAN, 12*USB, 2*PCI-E, 1*Mini-PCIe, ATX (305*244mm)
  • 支持Intel 6/7代Core i3/i5/i7及全系列LGA1151处理器
  • 采用Intel B150芯片组
  • 提供6*Mini-SAS (24*SATA), 3*Intel千兆LAN
  • 提供1*PCI-E 16X, 1*PCI-E 4X, 1*Mini-PCIe
  • 提供1*VGA, 3*HDMI, 支持三屏异显
规格
General
CPU Intel® Pentium®/ Celeron®/ Xeon® 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® B150 Chipset, TDP 6W
Memory Up to 32 GB DDR4 2133/1866 MHz, 4*DIMM
Storage 6*Mini-SAS (24*SATA), 1*SATA 3.0, 1*mSATA
Expansion Interface 1*PCI-E 16X, 1*PCI-E 4X, 1*Mini-PCIe (mSATA/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Server 2008/2012, Linux
I/O Interface
Serial Port 2*RS232 (1*RS485 optional)
USB 4*USB 3.0, 8*USB 2.0 (4*on rear I/O, 8*header)
Ethernet 3*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
3*HDMI: max resolution up to 4096*2160@30Hz
Multiple Display Triple
Mechanical & Environment
Dimension ATX, 305*244mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
