信步科技SV1-19016T主板规格
Intel Bay Trail J1900 CPU with eDP, 6*COM, 1*RJ11 Cash Drawer Control port, 1*Touch Panel Control header.
  • Supports Intel Bay Trail J1900 CPU
  • 6*COM, 8*USB, 1*1000 Mbps LAN
  • Supports dual display of 2*VGA and LVDS/eDP
  • Supports Cash Drawer Control port (RJ11) and Touch Panel Control header
  • Supports DC 12V or ATX Input (optional)
规格
General
CPU Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W
Chipset Null
Memory Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage 2*SATA 2.0
Expansion Interface 1*Mini-PCIe (mSATA/WiFi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux, Android
I/O Interface
Serial Port 6*RS232 (COM5 TTL optional)
USB 8*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 (Keyboard Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface 1*RJ11 Port (Cash Drawer)
1*Touch Panel Controller Pin Header
Display
Display Interface 2*VGA: max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU or DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
安卓
安卓
