信步科技SV3b-62026规格英文版
Intel Skylake-U 6th Gen Core i5-6200U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
  • Intel Skylake-U 6th Gen Core i5-6200U CPU
  • CPU at the solder side of M/B for Fanless heat dissipation
  • 6*COM, 8*USB, 2*1000 Mbps Intel LAN
  • 2*Mini-PCIe (Support 1*mSATA, 1*Wifi/3G/4G)
  • Supports triple display of VGA, HDMI and LVDS/eDP
  • 3.5'' (146*105mm)
规格
General
CPU Intel® Skylake-U CoreTM i5-6200U CPU, Dual-core, up to 2.80 GHz, TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 6*RS232 (up to 12*RS232 with SV-M6-CU)
USB 2*USB 3.0+6*USB 2.0 (up to 12*USB withSV-M6-CU)
Ethernet 2*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface 1*SVIO Connector
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 1920*1200@60Hz
Multiple Display Triple
Mechanical & Environment
Dimension 3.5'', 146*105mm
Power Input DC 9-28V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
嵌入式主板
