信步科技NVR SV6-B75A6主板英文版
Intel LGA1155 CPU with B75, 17*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E 16X, 2*Mini-PCIe, NVR Alarm port
  • Supports Intel 2nd & 3rd Gen Core i3/i5/i7 CPU and Pentium/ Celeron LGA1155 CPU with Intel B75 chipset
  • 17*SATA, 2*1000 Mbps Intel LAN
  • NVR Alarm port (RS485, 4*in/2*out GPIO)
  • 1*PCI-E 16X, 2*Mini-PCIe
  • Supports dual display of 1*VGA and 2*HDMI
规格
General
CPU Intel® Pentium®/ Celeron®/ 2nd and 3rd Generation CoreTM i3/i5/i7 CPU, LGA1155
Chipset Intel® B75 Chipset, TDP 6.7W
Memory Up to 16 GB DDR3 1600/1333/1066 MHz, 2*DIMM
Storage 4*Mini-SAS (16*SATA), 1*SATA, 1*mSATA
Expansion Interface 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows XP/7/8/10, Server 2008/2012, Linux
I/O Interface
Serial Port 2*RS232 (1*RS485 optional)
USB 4*USB 3.0, 4*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 2*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port Null
GPIO 8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO
Feature Interface 1*Alarm Port
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
2*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Micro-ATX, 254*210mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
