信步科技SV1a-302AN规格英文版
Intel® Celeron 1037U CPU, 1*VGA, 1*LVDS, 2*COM, 1*LAN, 1*Mini-PCIe, DC 12V Input
  • Intel® Celeron 1037U CPU
  • 2*COM, 8*USB, 1*100 Mbps LAN
  • Supports dual display of VGA and LVDS
  • 1*Mini-PCIe (Supports mSATA)
  • Supports DC 12V Input
  • Thin Mini-ITX (thickness≤17mm)
规格
General
CPU Intel® Celeron® 1037U CPU, Dual-core,1.8GHz, TDP 17W
Chipset Intel® NM70 Chipset, TDP 4.1W
Memory Up to 8 GB DDR3 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*SATA 2.0, 1*mSATA
Expansion Interface 1*Mini-PCIe (1*mSATA Supported)
BIOS AMI UEFI BIOS
System Windows XP/7/8/10, Linux
I/O Interface
Serial Port 2*RS232
USB 8*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 100Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1* LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 2048*1536@75Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
