Intel Xeon E3 v5 CPU (LGA1151) with C232, Supports ECC and IPMI, 10*SATA, 2*LAN, 3*PCI-E
| General | |
| CPU | Intel® Xeon®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
| Chipset | Intel® C232 Chipset, TDP 6W |
| Memory | Up to 32 GB DDR4 2133/1866 MHz, 4*DIMM, Support ECC |
| Storage | 6*SATA 3.0, 4* SATA 2.0 |
| Expansion Interface | 2*PCI-E 8X, 1*PCI-E 4X, 1*PCI, 1*Mini-PCIe |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Server 2008/2012, Linux |
| I/O Interface | |
| Serial Port | 2*RS232 |
| USB | 6*USB 3.0, 2*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Null |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface | 1*VGA: max resolution up to 1920*1080@60Hz |
| Multiple Display | Single |
| Mechanical & Environment | |
| Dimension | Micro-ATX, 244*244mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
