Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 18*SATA, 2*1000 Mbps Intel LAN, 1*PCI-E 16X, 1*Mini-PCIe, NVR Alarm port
| General | |
| CPU | Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
| Chipset | Intel® H110 Chipset, TDP 6W |
| Memory | Up to 32 GB DDR4 2133/1866 MHz, 2*DIMM |
| Storage | 4*Mini-SAS (16*SATA), 1*SATA 3.0, 1*mSATA/M.2 |
| Expansion Interface | 1*PCI-E 16X, 1*Mini-PCIe (mSATA/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Server 2008/2012, Linux |
| I/O Interface | |
| Serial Port | 2*RS232 (1*RS485 optional) |
| USB | 4*USB 3.0, 5*USB 2.0 (4*on rear I/O, 4*header, 1*on board connector ) |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO+4 in/ 2 out Opto-Isolated GPIO |
| Feature Interface |
1*Front Audio 1*Buzzer Mute |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | ATX, 275*210mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
