信步科技SV1-D5216主板规格特征英文版
Intel Atom D525 CPU, 6*COM, 1*LAN, 1*PCI, 1*Mini-PCIe
  • Intel Atom D525 CPU with Intel NM10 chipset
  • 6*COM, 8*USB, 1*100 Mbps LAN
  • Supports dual display of VGA and LVDS/VGA (use SV-M2-GL Extension Modules)
  • 1*PCI, 1*Mini-PCIe (Supports Wifi/3G/4G)
  • ATX Input, Supports DC 12V Input by using SV-PDC100 DC-ATX Module
规格
General
CPU Intel® AtomTM D525 CPU, Dual-core, up to 1.8 GHz, TDP 13W
Chipset Intel® NM10 Chipset, TDP 1.5W
Memory Up to 4 GB DDR3 800 MHz, 1*SO-DIMM
Storage 2*SATA 2.0
Expansion Interface 1*PCI, 1*Mini-PCIe (3G/4G/Wifi Supported)
BIOS Phoenix BIOS
System Windows XP/7, Linux
I/O Interface
Serial Port 6*RS232
USB 8*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 100Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 7 programmable GPIO
Feature Interface Null
Display
Display Interface 1*VGA: max resolution up to 2048*1536@60Hz
Multiple Display Single
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
