Intel® Atom D425 CPU, 6*COM, 1*LAN, 1*PCI, 1*Mini-PCIe
| General | |
| CPU | Intel® AtomTM D425 CPU, Dual-core, up to 1.8GHz,TDP 13W |
| Chipset | Intel® NM10 Chipset, TDP 1.5W |
| Memory | Up to 4 GB DDR3 800 MHz, 1*SO-DIMM |
| Storage | 2*SATA 2.0 |
| Expansion Interface | 1*PCI, 1*Mini-PCIe (3G/4G/Wifi Supported) |
| BIOS | Phoenix BIOS |
| System | Windows XP/7, Linux |
| I/O Interface | |
| Serial Port | 6*RS232 |
| USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 7 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface | 1*VGA: max resolution up to 2048*1536@60Hz |
| Multiple Display | Single |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
