信步科技SV1-25526P-B主板规格英文版
Intel Atom D2550 CPU, 6*COM, 2*LAN, 1*PCI, 2*Mini-PCIe, DC 12V or 24V ATX Input (optional)
  • Intel Atom D2550 CPU with Intel NM10 chipset
  • 6*COM, 7*USB, 2*1000 Mbps LAN
  • Supports dual display of VGA/HDMI/LVDS
  • 1*PCI, 2*Mini-PCIe
  • Supports SATA DOM
  • Supports DC 12V or 24V ATX Input (optional)
规格
General
CPU Intel® AtomTM D2550 CPU, Dual-core, 1.86 GHz, TDP10W
Chipset Intel® NM10 Chipset, TDP 1.5W
Memory Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 1*PCI, 2*Mini-PCIe (1*mSATA/3G/4G Supported, 1*Wifi Supported)
BIOS AMI UEFI BIOS
System Windows XP/7, Linux
I/O Interface
Serial Port 6*RS232 (COM3 TTL, COM6 RS485 optional)
USB 7*USB 2.0 (4*on rear I/O, 3*header)
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2 (Keyboard Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V or ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
