Intel® Atom N2600 CPU, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V Input, 3.5'' (146*105mm)
| General | |
| CPU | Intel® AtomTM N2600 CPU, Dual-core, 1.6 GHz,TDP 3.5W |
| Chipset | Intel® NM10 Chipset, TDP1.5W |
| Memory | Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM |
| Storage | 1*SATA 2.0, 1*mSATA |
| Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7, Linux |
| I/O Interface | |
| Serial Port | 6*RS232 (COM6 RS485 optional) |
| USB | 7*USB 2.0 (4*on rear I/O, 3*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz 1*LVDS: SingleChannel 18bit, max resolution up to 1440*900@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 3.5’’, 146*105mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
