信步科技SV3b-26016-C主板规格英文版
Intel® Atom N2600 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
  • Intel® Atom N2600 CPU with Intel NM10 chipset
  • CPU at the solder side of M/B for Fanless heat dissipation
  • 6*COM, 7*USB, 1*1000 Mbps LAN
  • Supports dual display of VGA and LVDS
  • 2*Mini-PCIe (Supports 1*mSATA, 1*Wifi+3G/4G)
  • Supports DC 12V Input
  • 3.5'' (146*105mm)
规格
General
CPU
Intel® AtomTM N2600 CPU, Dual-core, 1.6GHz, TDP 3.5W
Chipset
Intel® NM10 Chipset, TDP 1.5W
Memory
Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM
Storage
1*SATA 2.0, 1*mSATA
Expansion Interface
2*Mini-PCIe1*Wifi/3G/4G Supported, 1* mSATA Supported
BIOS
AMI UEFI BIOS
System
Windows XP/7, Linux
I/O Interface
Serial Port
6*RS232COM5 RS485 or TTL optional
USB
7*USB 2.04*on rear I/O, 3*header
Ethernet
1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec,supports MIC/Line-out Ports
PS/2
1*PS/2 (Keyboard and Mouse Supported)
Parallel Port
1* LPT
GPIO
8 programmable GPIO
Feature Interface
Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS: SingleChannel 18bit, max resolution up to 1440*900@60Hz
Multiple Display
Dual
Mechanical & Environment
Dimension
3.5", 146*105mm
Power Input
DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
WINDOWS
