Intel® Apollo Lake Celeron N3450 CPU, Supports triple display, 2*LAN, 2*Mini-PCIe, DC 12V Input
| General | |
| CPU | Intel® Apollo Lake N3450 CPU, Quad-core, up to 2.2 GHz, TDP6W |
| Chipset | Null |
| Memory | Up to 8GB DDR3L 1866 MHz, 1*SO-DIMM |
| Storage | 2*SATA 3.0, 1*mSATA |
| Expansion Interface | 2*Mini-PCIe (1*Wifi/3G/4G 1* mSATA Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux |
| I/O Interface | |
| Serial Port | 4*RS232 |
| USB | 2*USB 3.0, 6*USB 2.0 (2*on rear I/O, 6*header) |
| Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI:max resolution up to 4096*2160 1*LVDS/eDP : DualChannel 24bit, max resolution up to 1920*1200; eDP max resolution up to 1920*1080 |
| Multiple Display | Triple |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
