信步科技OPS-H81主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, OPS, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 19V Input
  • Supports Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with Intel H81 chipset
  • Provides OPS port for Digital White Board
  • Supports dual display of VGA, HDMI and DP, UHD 4K
  • 1*1000 Mbps LAN and 2*Mini-PCIe
  • Supports DC 19V Input
规格
General
CPU Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150
Chipset Intel® H81 Chipset, TDP 4.1W
Memory Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0 (22Pin), 1*mSATA
Expansion Interface
2*Mini-PCIe (1*Wifi/3G/4G Supported, 1* mSATA Supported)
1*OPS Port
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 1*RS232
USB 2*USB 3.0+4*USB 2.0 (rear I/O), 1*USB 3.0+2*USB 2.0 (OPS)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 Null
Parallel Port Null
GPIO Null
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 4096*2304@24Hz
1*OPS_HDMI: max resolution up to 4096*2304@24Hz
1*OPS_DP: max resolution up to 3840*2160@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 170*190mm
Power Input DC 19V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
