信步科技SV1a-H8112P-B主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, 1*LVDS, 4K UHD, 2*Mini-PCIe, DC 19V Input
  • Supports Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with Intel H81 chipset
  • Supports 4K UHD display
  • Supports dual display of VGA /HDMI/LVDS
  • 1*1000 Mbps LAN, 2*Mini-PCIe
  • Supports DC 19V Input
规格
General
CPU
Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150
Chipset
Intel® H81 Chipset, TDP 4.1W
Memory
Up to 16 GB DDR3 1600/1333 MHz, 2*SO-DIMM
Storage
1*SATA 3.0, 2*SATA 2.0
Expansion Interface
2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS
AMI UEFI BIOS
System
Windows 7/8/10, Linux
I/O Interface
Serial Port
2*RS232
USB
2*USB 3.0, 6*USB 2.0 (4*on rear I/O, 4*header)
Ethernet
1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2
1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port
Null
GPIO
8 programmable GPIO
Feature Interface
Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 4096*2304@24Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display
Dual
Mechanical & Environment
Dimension
Mini-ITX, 170*170mm
Power Input
DC 19V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
