信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
  • Supports Intel 4th Gen Core i3/i5/i7 CPU and Pentium/ Celeron LGA1150 CPU with Intel H81 chipset
  • 6*COM, 10*USB, 2*1000 Mbps LAN
  • Supports dual display of VGA and DVI
  • 1*PCI-E 16X, 1*PCI-E 4X, 1*PCI-E 1X, 4*PCI
  • 1*Mini-PCIe (Supports mSATA)
规格
General
CPU Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150
Chipset Intel® H81 Chipset, TDP 4.1W
Memory Up to 16 GB DDR3 1600/1333 MHz, 2*DIMM
Storage 1*SATA 3.0, 2*SATA 2.0, 1*mSATA
Expansion Interface 1*PCI-E 16X, 1*PCI-E 4X, 1*PCI-E 1X, 4*PCI, 1*Mini-PCIe(mSATA Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 6*RS232 (COM3 RS485 optional)
USB 2*USB 3.0, 8*USB 2.0 (4*on rear I/O, 6*header)
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 2*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*DVI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension ATX, 305*220mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
