Intel® Bay Trail J1800 CPU, 6*COM, 10*USB, 1*LAN, 1*Mini-PCIe
| General | |
| CPU | Intel® Bay Trail J1800 CPU, Dual-core, up to 2.58 GHz, TDP10W |
| Chipset | Null |
| Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 2.0, 1*mSATA |
| Expansion Interface | 1*Mini-PCIe (mSATA Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux, Android |
| I/O Interface | |
| Serial Port | 6*RS232 (COM3 TTL optional) |
| USB | 10*USB 2.0 (4*on rear I/O, 6*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface | 1*VGA: max resolution up to 2560*1600@60Hz |
| Multiple Display | Single |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
