信步科技SV1a-19014P-C主板规格英文版
Intel® Bay Trail J1900 CPU, 4*COM, 1*LAN, 2*Mini-PCIe, DC 12V Input
  • Intel® Bay Trail Celeron J1900 CPU
  • 4*COM, 9*USB, 1*1000 Mbps LAN
  • Supports dual display of VGA and LVDS
  • 2*Mini-PCIe (Supports 1*mSATA,1*Wifi/3G/4G)
  • Supports DC 12V Input
  • Thin Mini-ITX (thickness≤17mm)
规格
General
CPU Intel® Bay Trail J1900 CPU, Quad-core, up to2.42 GHz, TDP 10W
Chipset Null
Memory Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux, Android
I/O Interface
Serial Port 4*RS232 (COM3 TTL optional)
USB 1*USB 3.0, 8*USB 2.0 (4*on rear I/O, 5*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channelHDA Codec, supports MIC/Line-out Ports
1*Amplifer
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
