信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
  • Intel Bay Trail Celeron J1900 CPU
  • CPU at the solder side of M/B for Fanless heat dissipation
  • 6*COM, 7*USB, 2*1000 Mbps Intel LAN
  • 2*Mini-PCIe (Support 1*mSATA, 1*Wifi/3G/4G)
  • Supports dual display of VGA/HDMI/LVDS
  • 3.5'' (146*105mm)
规格
General
CPU Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W
Chipset Null
Memory Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux, Android
I/O Interface
Serial Port 6*RS232 (COM6 RS485 optional)
USB 1*USB 3.0+6*USB 2.0 (2*on rear I/O, 5*header)
Ethernet 2*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 3.5'', 146*105mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
安卓
安卓
安卓
