信步科技NVR SV1-1908主板规格英文版
Intel® Bay Trail J1900 CPU, 9*SATA, 2*1000 Mbps Intel LAN, 1*Mini-PCIe, NVR Alarm port
  • Intel® Bay Trail Celeron J1900 CPU
  • 9*SATA, 2*1000 Mbps Intel LAN
  • 1*Mini-PCIe (Supports mSATA)
  • NVR Alarm port (RS485, 4*in/2*out GPIO)
  • Supports dual display of 1*VGA and 2*HDMI
规格
General
CPU
Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W
Chipset
Null
Memory
Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage
9*SATA 2.0, 1*mSATA
Expansion Interface
1*Mini-PCIe (mSATA Supported)
BIOS
AMI UEFI BIOS
System
Windows 7/8/10, Server 2008/2012, Linux, Android
I/O Interface
Serial Port
2*RS232 (1*RS485 optional)
USB
7*USB 2.0 (4*on rear I/O, 3*header)
Ethernet
2*Intel® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2
Null
Parallel Port
Null
GPIO
8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO
Feature Interface
1*Alarm Port
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
2*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display
Dual
Mechanical & Environment
Dimension
Mini-ITX, 170*170mm
Power Input
ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
安卓
安卓
