信步科技SV1-13716P-B主板规格英文版
Intel® Celeron 1037U CPU with NM70, 6*COM, 1*LAN, 2*Mini-PCIe, 1* RJ11 Cash Drawer Control port, DC 12V Input
  • Intel® Celeron 1037U CPU with Intel NM70 chipset
  • Supports Cash Drawer Control port (RJ11)
  • 6*COM, 7*USB, 1*1000 Mbps LAN
  • 2*Mini-PCIe (Supports 1*mSATA, 1*Wifi+3G/4G)
  • Supports dual display of 2*VGA and 1*LVDS
  • Supports DC 12V Input
规格
General
CPU Intel® Celeron® 1037U CPU, Dual-core, 1.8 GHz, TDP17W
Chipset Intel® NM70 Chipset, TDP 4.1W
Memory Up to 8 GB DDR3 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0, 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe(1*mSATA Supported, 1*3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows XP/7/8/10, Linux
I/O Interface
Serial Port Windows XP/7/8/10, Linux
USB 7*USB 2.0 (4*on rear I/O, 3*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channelHDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface
1*FPC(without USB)
1*RJ11 (Cash Drawer)
Display
Display Interface
1*VGA: max resolution up to 2048*1536@75Hz
1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS: Dual channel 24 bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
