信步科技SV1a-61014P主板规格英文版
Intel Skylake-U Core i3-6100U处理器, 1*VGA, 1*HDMI, 1*LVDS/eDP, 支持三屏异显, 1*LAN, 2*Mini-PCIe
  • 采用Intel Skylake-U Core i3-6100U处理器
  • 提供1*VGA, 1*HDMI, 1*LVDS/eDP, 支持三屏异显
  • 提供4*COM, 10*USB, 1*千兆LAN
  • 提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
  • 采用DC 12V供电
  • 薄型Mini-ITX,板身厚度≤17mm
规格
General
CPU Intel® Skylake-U CoreTM i3-6100U CPU, Dual-core, 2.3 GHz, TDP 15W
Chipset Null
Memory Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 4*RS232 (COM3 TTL optional)
USB 2*USB 3.0, 8*USB 2.0 (4*on rear I/O, 6*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface 1*Cash Drawer wafer
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz
                      eDP, max resolution up to 1920*1200@60Hz
Multiple Display Triple
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
