Intel LGA1155全系列处理器, 17*SATA, 2*Intel千兆LAN, 1*PCI-E 16X, 2*Mini-PCIe, NVR专用报警端子
| General | |
| CPU | Intel® Pentium®/ Celeron®/ 2nd and 3rd Generation CoreTM i3/i5/i7 CPU, LGA1155 |
| Chipset | Intel® B75 Chipset, TDP 6.7W |
| Memory | Up to 16 GB DDR3 1600/1333/1066 MHz, 2*DIMM |
| Storage | 4*Mini-SAS (16*SATA), 1*SATA, 1*mSATA |
| Expansion Interface | 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7/8/10, Server 2008/2012, Linux |
| I/O Interface | |
| Serial Port | 2*RS232 (1*RS485 optional) |
| USB | 4*USB 3.0, 4*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO |
| Feature Interface | 1*Alarm Port |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Micro-ATX, 254*210mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
