Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子
| General | |
| CPU |
Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W |
| Chipset |
Null |
| Memory |
Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
| Storage |
9*SATA 2.0, 1*mSATA |
| Expansion Interface |
1*Mini-PCIe (mSATA Supported) |
| BIOS |
AMI UEFI BIOS |
| System |
Windows 7/8/10, Server 2008/2012, Linux, Android |
| I/O Interface | |
| Serial Port |
2*RS232 (1*RS485 optional) |
| USB |
7*USB 2.0 (4*on rear I/O, 3*header) |
| Ethernet |
2*Intel® PCI-E LAN for 1000Mbps |
| Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 |
Null |
| Parallel Port |
Null |
| GPIO |
8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO |
| Feature Interface |
1*Alarm Port |
| Display | |
| Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
| Multiple Display |
Dual |
| Mechanical & Environment | |
| Dimension |
Mini-ITX, 170*170mm |
| Power Input |
ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
