信步科技NVR SV4-B85B4主板规格英文版
Intel LGA1150全系列处理器, 26*SATA, 3*Intel千兆LAN, 2*PCI-E, 1*Mini-PCIe, NVR专用报警端子
  • 支持Intel 4代Core i3/i5/i7及全系列LGA1150处理器
  • 采用Intel B85芯片组
  • 提供6*Mini-SAS (24*SATA), 2*SATA 3.0, 3*Intel千兆LAN
  • 提供NVR专用报警端子(RS485, 4 in/2 out*GPIO)
  • 提供1*PCI-E 16X, 1* PCI-E 1X, 1*Mini-PCIe
  • 提供1*VGA, 2*HDMI, 支持三屏异显
规格
General
CPU Intel® Pentium®/ Celeron®/ Xeon®/4th Generation CoreTM i3/i5/i7 CPU, LGA1150
Chipset Intel® B85 Chipset, TDP 4.1W
Memory Up to 32 GB DDR3 1600/1333 MHz, 4*DIMM
Storage 6*Mini-SAS (24*SATA), 2*SATA 3.0
Expansion Interface 1*PCI-E 16X, 1*PCI-E 1X, 1*Mini-PCIe (mSATA Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Server 2008/2012, Linux
I/O Interface
Serial Port 2*RS232 (1*RS485 optional)
USB 4*USB 3.0, 4*USB 2.0 (2*on rear I/O, 2*on front I/O, 4*header)
Ethernet 3*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port Null
GPIO 8 programmable GPIO, 4 in/2 out Opto-Isolated GPIO
Feature Interface
1*Alarm Port
4*Thermal Sensor
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
2*HDMI: max resolution up to 4096*2304@24Hz
Multiple Display Triple
Mechanical & Environment
Dimension ATX, 305*244mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
